6 members (Dave1234, TUTS 59, Peggy M, Wayne67vert, joe apple, 1 invisible), 74 guests, and 4 robots.
Topics128,206
Posts1,057,440
Members48,471
1 Offline
Is a 1 ton rear same as a 1 ton front bumper?
Is the rear bumper bracket bolted to outside of 1 ton frame channels?
Does the bracket curve down ward or upward?
Thanks , Jerry
Thanks , Jerry
Not on a pickup.
Yes, on a panel-body.
I have more zippers then a pair of cargo pants
Not on a pickup.
Never knew that but it's good to know thumbs_up ...joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
As for the mounting of the brackets, check out mine.
Dave Baird
1951 Chevy 3803
1 Offline
1 Offline
OK, To answer any questions out there, here is what I have discovered and it answers my own question. The 3800 panel rear bumper matches its front, curvature of its brackets are identical. They appear identical to the 3804 1 ton pickup front bumper. The 3804 one ton rear bumper is a breed of its own, being quite straight when comparing it to the one ton truck front and panel front/rear. If that is as clear as mud to you, then you understand it as well as I, Using a 1 ton rear from a panel will NOT work on a 1 ton pickup. Any questions, contact me. Jerry
That is almost correct:
- the front and rear bumpers on a 1-ton panel-body are the same
- the front and rear bumpers on a 1-ton pickup would indeed be different because GM apparently did not sell a rear bumper (did you find a part number for a rear bumper?)
1929-1957 Master Parts Book (SGL. UNIT indicates Panel body trucks)
What parts book are you referring to?
Pickup
- front = 3700437/painted (3683347/chromed)
- rear = no rear bumper listed?
Panel
front = 3700437 (3683347/chromed)
rear = 3700437 (3673347/chromed)
1 Offline
Wishful thinking by me Tim? , Maybe I read between the lines. Any how, you are correct. I was looking at that same parts book and recall seeing the same numbers.
I was surprised to find no rear bumper listed.
A rear bumper was an option on the 3800 series trucks.
The rear frame widths on the 3600 and larger trucks was 36" with the exception of 6702 and 6802 chassis.
I do remember seeing a part listing for that had the same brackets and bumper for the 3600 and 3800 truck.
With that being said, a 3600 rear bumper would be a direct fit.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Moderated by  Dusty53
