0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
1953 Chevrolet 3100, converted to 12 volts with alternator. Drove my truck today and amp gauge shows charging max all the time. Battery was almost 5 years old so I replaced it. Same charging status with new battery. New battery showing 13 plus volts with engine off. In the past at start up, amp gauge would be in the middle or minus until engine rpm rose up, then show plus charge.
So, can the alternator fail in the "charge only" position?
Alternator is 7 years old but not many miles on it. One of these:
http://www.oldchevytrucks.com/cart/index.asp?sdes=rehp136
Can I buy one at a FLAPS?
Thanks for any input. Joe
H Online: Content
Yes, it can. If the regulator supplies full voltage to the field coils the alternator will go into full current output and severely overcharge the battery. A shorted power transistor in the regulator will full-field it. At speeds above idle, the voltage can go to 20+ volts or more.
Riding in the Passing Lane
Check the voltage when it is running. If it goes much over 14 volts the regulator is bad like Lincoln says. Repair it emidiatly or you will damage the bat. & electrical components.
1972 Chevy c10 Cheyenne Super
Thanks Hotrod and Wrenchbender. I will take your advice and replace or repair the alternator.
Found this info on this site, maybe it will help someone in the future.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=691757&page=1
http://www.madelectrical.com/electricaltech/delcoremy.shtml
Joe
Is that a 1 wire alternator? If it is a 3 wire I can put a new reg. in it for you. I'm right over there in Northmoor.
George
Thanks for the offer George. I already have it at a repair shop.
Joe
