5 members (Otto Skorzeny, sron48, klhansen, k2handyman, Hotrod Lincoln), 126 guests, and 2 robots.
Topics128,041
Posts1,055,483
Members48,424
#1065930 11/01/2014 10:22 PM
I need to get around the drivers side exhaust manifold to reach the input shaft on the R&P. Summit,Jegs etc,etc sell U-joints for this purpose.Probably need 2 U-joints to accomplish this. My question is. Does each joint have to be supported and how do I do this? Thanks in advance for any help. I have seen street rods at shows with steering systems that have multiple U-joints and really snake around their obstacles.
Weeds
I have used a heim joint mounted to a bracket that is welded to the frame.
http://www.speedwaymotors.com/Steel-Heim-Joint-Rod-Ends-for-Steering-Shaft-3-4-16-RH-Male-757-Hole,84.html
Visit this site www.borgeson.com. You should be able to learn all you need to know from them. Things to know...there is a max. angle for a u-joint, 37 degrees if I remember correctly. One u-joint, no support needed, two then yes. You will most likely need one at your steering box, this counts. Welding on the steering shaft is a no-no, but have seen it many times. Pay close attention to such things as spline count at your steering box, do you need a vibration damper aka rag joint, and several others.
Don and Belt, thanks for the reply and information. I have been to Borgesons site and I think I will need at least 2 Heims. The R&P already has the rag joint,1 u joint and a short double d shaft.
Weeds
H Online: Content
Where is the rack & pinion going to be mounted? It sounds like you might be thinking about using one on a straight-axle setup, and there can be some serious safety concerns with that type of system. PM me if you like- - - -not wanting to get into a public whizzing contest, just concerned!
Where is the rack & pinion going to be mounted? It sounds like you might be thinking about using one on a straight-axle setup.
Jerry,Weeds is using a Scott Danforth IFS.
Weeds like beltfed mentions any more than two UJs and you'll need a support bearing,Borgesson do them as do Summit racing.
Here's how I did mine. Steering hook-up.
I should add I replaced the bolts with grade 8s and have since added a gusset from the bracket to the top of the chassis since this pic was taken,it steers straight and smooth...
More pix on Flickr.
Jerry,Thanks for your concern and the reply. Like Jock says I am using Scott Danforths crossmember and the R&P ends up in front of the crossmember. The splined input shaft points almost right at the drivers side manifold but I think there is room to get around it with the proper use of U-joints and supports. I suspected the joints needed to be supported but I didn't know for sure so that was my question. Thanks for any advice you can give me.
Jock, thanks also for your reply and the pics. It gives me an idea or 2 on how to accomplish this. Might have to wait until spring tho as it is getting pretty cold here in badgerland and if it snows i'll be waiting until spring for sure.
weeds
