2 members (59 fleet, KEVINSKI),
157
Mod | | | Forums66 Topics128,034 Posts1,055,551 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | What are your opinions on just putting a clear coat on a truck and enjoying the patina? And is there anything that I need to know if I were to do it?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | I would skip the clear coat and enjoy the patina as is, at least if you park it indoors. It will never rust enough to cause appreciable damage in your lifetime if you don't drive it in the winter. | | | | | Joined: May 2012 Posts: 30 New Guy | | New Guy Joined: May 2012 Posts: 30 | I can tell you from experience, rust will bubble and cause yellow spiderwebs under the clear especially if out in the sun much. It only works good if it has all paint and just fading and peeling. It might last a year and then start to look like crap if even that long then you will have to start from bare bottom. | | |
