| | | Forums66 Topics128,194 Posts1,057,262 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | I am 'fixin' to install the runningboards on my truck. Do you attach the splash apron on the rear fender first or do you put the running boards on first? It appears to me it will be difficult to position and attach the splash apron if you put the runningboards on first.
Richie West
| | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I am guessing this is on the 50 1/2 ton you list in your profile?
If so, do you already have the bed on? If the bed is on the frame you can bolt the splash apron to the runningboard and then install as a unit. Or, install the runningboard first then install the splash apron. The splash apron will fit with the running board in place, just be careful not to scratch the paint. You can do it either way. Don't forget there is on bolt hole on the splash apron that will bolt to the rear fender.
Good luck!! | | | | | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | I think it's a little easier to use a modern adhesive to "bond" the bed to runningboard apron to the runningboard, then using fender welting between the splash apron and bed, go on and bolt it all up. Fender welt or "Anti Squeak" is recommended. | | |
