4 members (Pre '68 Dave, Steveoreno, Nick in Manitou, Bill Hanlon), 105 guests, and 1 robot.
Topics128,198
Posts1,057,272
Members48,466
#106586 11/14/2003 3:30 AM
Junior Member
Junior Member
I am 'fixin' to install the runningboards on my truck. Do you attach the splash apron on the rear fender first or do you put the running boards on first? It appears to me it will be difficult to position and attach the splash apron if you put the runningboards on first.
Richie West
#106587 11/14/2003 4:02 AM
I am guessing this is on the 50 1/2 ton you list in your profile?
If so, do you already have the bed on? If the bed is on the frame you can bolt the splash apron to the runningboard and then install as a unit. Or, install the runningboard first then install the splash apron. The splash apron will fit with the running board in place, just be careful not to scratch the paint. You can do it either way. Don't forget there is on bolt hole on the splash apron that will bolt to the rear fender.
Good luck!!
#106588 11/15/2003 12:32 AM
I think it's a little easier to use a modern adhesive to "bond" the bed to runningboard apron to the runningboard, then using fender welting between the splash apron and bed, go on and bolt it all up. Fender welt or "Anti Squeak" is recommended.
