| | | Forums66 Topics128,100 Posts1,056,510 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | From time to time I see the question or comment referring to the ugly sheet metal someone added under the jump seat. The fact is,it's original sheet metal in my picture.I cut the spot welds and removed it to repair a hole in the floor pan under it.I don't think Ive ever seen anyone post a picture of the under side. The panel is spot welded to the floor and slips under the seat riser where three bolts hold it. sheet metal under jump seat jump seat removed bottom side of sheet metal under jump seat floor pan under sheet metal As you can see in the last picture,there are three weld nuts attached to the sheet metal. Just wanted to share it with all you 1947.2 to 1955.1 suburban folks. Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2005 Posts: 4,256 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,256 | | | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | My body man had a fit after we made and installed the new floor,then covered it up with that flat sheet metal. I finally won him over , we are both in counseling now !
52 suburban 48 Palace
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | That recessed floor under the flat sheet metal on the Suburban is what would be in the panel truck. It was part of a storage cavity under the seat platform. GM obviously didn't want to stamp out a floor for the Suburban and another floor for the panel. The seat mount platform on the panel truck extends to the door, whereas on the Suburban it stops at the location of the jump seat. That's why that thick gauge flat sheet metal is spot welded and bolted under the jump seat. | | |
