2 members (Steveoreno, Tinker5), 141 guests, and 2 robots.
Topics128,204
Posts1,057,299
Members48,467
I will be needing to remove and replace both check valves. I read in another thread a reference to some potential difficulty in doing this. I tried to order the special tool to do this from Zenith when ordering some other rebuild parts, but was told that it was no longer available. How can I accomplish this using commonly available tools without messing up the bowl casting? Thanks!
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
Carburetion specialist
You can make a tool that will suffice.
Call, and I will explain how. Then, if you wish, you may type the method here.
573-392-7378 (9-4 Mon-Tues central time).
Jon.
The Carburetor Shop
Thanks, Jon. Dave
Get a 3 or 4 inch drywall screw. Screw into the center of the check valve, pull out.
http://www.tm9-801.com/forums/viewtopic.php?f=1&t=468
That doesn't sound too complicated.
Jon recommended making a small slidehammer that consists of 1) a machine screw to thread into the checkvalve, brazed onto 2) a 3/16"X6" long bolt to serve as the shaft, with 3) a 1/4" nut slid over the screw-and-bolt assembly to serve as the sliding weight. That sounds a lot like my mental picture of the factory tool described in the GMC shop manual. Thanks, Jon.
