| | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | I have a newly rebuilt 235 for my 58. I installed a rebuilt dual action fuel pump in April and it began to leak at the lower flange last month. I tightened the screws but it continued. Concerned that it may be leaking inside, I replaced the pump with another from a vender and changed the oil. The new pump has started to leak at the lower flange as well. Any ideas what may be causing this? It is not dripping but the gasket and area around the screws is wet. Please advise. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | You didn't say but I'm guessing you also changed the gasket correct? If so, check and make sure the draft tube is drafting. Easiest way would be to blow air into the draft tube exit pipe and see if it blows through into the engine.
If the draft tube is clogged up it won't relieve internal pressure and this pressure will find its way out, most times through seal and gasket locations.
Good luck Dave | | | | | Joined: Feb 2010 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 51 | Thanks Dave. I used a new fuel pump/block gasket. I assume the draft pipe is the hose or tubing from the "out" port? I'll check to make sure it is clean and has air coming out. | | |
