5 members (MRMEROTH11, TrknGMC, TUTS 59, Gray_Ghost, panic), 127 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
#1065277 10/29/2014 7:24 PM
On the 216, does the front main bearing have 4 bolts? Having difficulty removing.
Thanks. Scott
scottss60 #1065284 10/29/2014 7:48 PM
Yes. The cap is held on with two vertical and two horizontal bolts.
scottss60 #1065325 10/29/2014 11:05 PM
The two horizontal bolts thread into the timing cover
scottss60 #1065331 10/29/2014 11:41 PM
Thanks guys go it off. Want to replace the main and rod bearings. I have a 53, been checking around and have been asked if I have a 216 or 235 engine. Thought it was a 216. engine serial number by dip stick does not seem to match numbers I have found on line. Does it matter 216 or 235 for the bearings and can you recommend a vender? Thanks, Scott
scottss60 #1065338 10/30/2014 12:04 AM
What is the Engine Serial Number?
scottss60 #1065350 10/30/2014 12:56 AM
Tim, this a above the dip stick:AD CA 54 69 60
Thanks!
scottss60 #1065366 10/30/2014 1:29 AM
If your engine is a '53 it won't have rod bearing inserts, you can have your rods machined for insert bearings.
scottss60 #1065378 10/30/2014 1:44 AM
scottss60 #1065384 10/30/2014 2:06 AM
Thanks Tim, how does that impact bearing replacement?
scottss60 #1065388 10/30/2014 2:19 AM
Scott, you have your same questions asked in to many posts.
I have addressed this in one of your other posts.
My Blog
scottss60 #1065390 10/30/2014 2:23 AM
Scott,
I do not have any experience with an engine older than 1948.
The Shop Manual describes a complex procedure for main bearing replacement (compared to later engines).
The rods have babbitted bearings - the bearing is an integral part of the rod assembly. These types of rods were used up into 1953. I bought new rods to match my crankshaft - that was a long time ago.
Someone who has rebuilt one of those engines (in modern times) will reply.
scottss60 #1065391 10/30/2014 2:24 AM
Scott,
Dave is the expert. Read carefully what he has posted.
scottss60 #1065396 10/30/2014 2:31 AM
Thanks..got carried away..
Dave, will review..btw, checked the distributor and it was not in all the way as u suggested.. went in about 1/4 inch deeper.
Thanks for your suggestion.
scottss60 #1065410 10/30/2014 3:13 AM
I would like to add at this time that it would be a miracle if the crank is not ruined/ needing reground.
Running without oil pressure for 10 minutes can do a lot of damage to it.
You could be lucky but I would think about that 235 swap you mentioned.
My Blog
scottss60 #1065421 10/30/2014 4:24 AM
Maybe that explains why I cannot turn the engine by hand using a crow bar..despite all the bearings removed, main and rod, and able to turn the flywheel with pry bar but not the crank...
