3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#1065249 10/29/2014 3:34 PM
I recently purchased replacement brake adjusters for the rear of my 1 1/2 ton. They are the disc type with the bolt head. My question is: How were the discs fastened to the flat on the bolt? Was the end of the bolt just peened over the disc, or how does it stay on?
Saving American history one rust bucket at a time. When they're gone, they're gone forever!
Year and make of truck?
Sorry, 1946 Chevy 1 1/2 ton rear end
Just shooting from the hip but if your truck is like my '50 COE, the end of the bolt is peened over the disc. My truck has Huck brakes which should be the same as yours and my adjusters are OK so far. Just in case I have problems in the future, I was able to obtain NOS replacement bolts and discs and I had the same question. Looking at the adjusters on the truck, they are peened on. I think it would be difficult to do this on the truck and might require removal of the backing plate so you can put the assembly in a press.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Yes they originally were peened over to attach, not the most durable fastening technique. They can be MIG welded on, just try to do it without building up enough heat to damage the spring. I welded mine similar to the way you would weld sheet metal, a little spot here, let cool; a little spot there, let cool. I would imagine picking a good cool/cold day in WI would work well in dissipating heat as well.
Lots more pictures
Thanks! Just welded em on as recommended. Work great. Thanks again !
Ok I might be late here but i just had some trouble with mine.
I welded the disc to the bolt, yes it was originally peened. It doesnt take much and you wont hurt the springs.
The problem was the lack of clearance between the weld on the disc face and the adjuster cap on the slave cylinder. The adjuster cap has the teeth all around the outside, was aftermarket, made in argentina, and the casting was machined about 2mm .080" off centre so that for half the turn it jammed on the adjuster disc. The brakes were firm at the pedal but did not work. You could not see it with the drum off, as the shoes can move free with the drum off. I found the problem at a local testing station's rolling road brake tester.
So careful not to use too much weld!
I mounted the adjuster cap on internal jaws in the lathe, turned it properly round, filed the teeth, and fixed it. And ground the weld on the adjuster disc down a bit.
'47 Canadian RHD 1.5 ton truck
