1 members (joe apple), 110 guests, and 3 robots.
Topics128,089
Posts1,056,139
Members48,435
#1064934 10/28/2014 4:32 AM
My recently acquired '55 2nd series doesn't have an emergency brake. On the heritage site it shows the E brake as optional. So I was wondering if there are any pics or descriptions of the e-brake so I can start putting it together. Any detail is mucho appreciated.
Thanks!
a hand brake was not "optional", there were 2 different setups - if it's a light truck with a 3 speed it had a lever under the left side of the dash for cable operation of the rear brakes - med & heavy trucks with the 4 speed had a driveshaft brake with a lever next to the shifter thru the floor
either e-brake arrangement isn't simple, there are a range of pieces, and if you don't have any of either version your best bet is to get the 55-59 assembly manual so you know what you're looking for, or find a nearby truck of the same model [55-59, 1/2, 3/4, 1T] to borrow parts from .... there's also some helpful pics in the shop manual, which can be found here
Sir Searchalot
Sir Searchalot
The Heritage info does not state a RPO for Ebrake but shows it on PP 117 as standard. Rods and cables or on-drum, depending on model as Bill states.
Once you see how it is all mounted, you will probably discover some provisions for it on your truck if you have a stock frame. Some are riveted on and are unlikely to have been removed. You can also acquire the parts from time to time on Ebay. Don't see a pic of truck in your signature.
I do not know Task Force trucks, so I am not sure about an E-brake (Emergency-brake).
I think this is the more common parking brake (55-2nd).
Here are the less common parking brakes (55-2nd):
Propeller shaft parking brake #1 - 1 ton
Propeller shaft parking brake #2 - 1.5 and 2 ton
Sir Searchalot
Sir Searchalot
That's it. Great pictures! Excellent effort indeed, not skiving. They are parking brakes. Can be used in an emergency, while driving, if the hydraulics fail.
Thanks guys ... good work! This gives me a great starting point to get mine back together.
