0 members (),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | 235 engine, I adjusted the valves, and checked them again today, and they are all spec ok. .006 and .018. I'm hearing a clicking ticking sound that sounds louder than valve clatter, but only at one particular relatively low part throttle rpm. It sounds like something is loose, or rattling around, Almost a clank, but only at one part throttle setting. But that, of course, is normal drive down the road speed. Any ideas or suggestions what to check next? | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | oops,, I just read
dump her or work on our relationship? 235 woes
about lifters and lifter bore? might I have the same issue? | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Stock engine setup and components? | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Yes, to the best I know. Just finished tune-up, points plugs wires etc. It's running very well. but this new noise has me concerned. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Like a chatter sound when your around 2200-2500 ish rpm when holing steady on the gas? | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have just gone thru a similar sounding issue.
After pulling the engine and examining stuff , I found the fibre cam gear was worn enough to have excessive backlash to the crank gear.
New fibre gear fixed my noise | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Yes, wolfcub. steady on gas clatter at low 2000 ish rpm.
and dusty, sounds like I should check that gear. Must I pull engine? Or is it just up front by the water pump? | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | One quick item to check would be the heat riser valve in the exhaust manifold, the sheet metal flap can come loose causing odd noises.
Before pulling the engine apart, use a long stick and place it on the timing cover and the other end up to your ear, then hold the throttle open. You should be able to hear the chain hit the cover pretty clearly.
Joe | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there is no chain in these engines | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | fibre cam gear???
Real stovebolt 216/235/261 truck engines did not use them - real truck/Corvette stovebolts had metal/aluminum cam gears.
But, I think that Pre '68 Dave uses fibre cam gears on all rebuilt stovebolt engines (for less noise).
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would not say I use fiber on all, but I prefer them. If you check run-out closely on an aluminum gear, and make sure it runs true, they will be almost as quiet.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | I knew that about gears, not sure what I was thinking. The stick or screw driver is still a good easy tool to find a noise.
Joe | | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | Is it written in stone somewhere that all truck engines came with aluminum timing gear?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is it written in stone somewhere that all truck engines came with aluminum timing gear? What years and engines, Carl? I referred to 216/235/261 USA truck engines (and the Corvette 235). I doubt that it can be found to be written in stone, but most likely it is printed in ink in Master Parts Catalogs (up to 1957 is on-line - http://chevy.oldcarmanualproject.com/ - Group 0.736). I do not have a MPC for trucks after 1957. http://www.oldchevytrucks.com/cart/product.asp?prodid=ME439A&i=10423||||| | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | A bent pushrod can make an intermittent noise.
| | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | You seemed to answer yes to all my questions about when and how the sound comes about. Granted your running a stock distributor but as soon as I disconnected my non stock vacuum advance the sound / chatter went completely away. No change in performance that i can feel or hear also. The instructions even say that possible disconnection and or alterations to one or both carbs might be required to fine tune my setup. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Thanks, I'll check the pushrods, and try disconnecting the stock vacuum advance. | | |
