5 members (GradyB, Joe H, Leo, 60steve, 1 invisible),
164
Mod | | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | i ordered a new oil line that runs from oil pump to rockers and after looking at it more it looks like it must come in pieces....the line goes down from the rockers to the passenger side of block right in front of the distributor above the lifters......now my question is....does the oil line unbolt there for a simple partial replacement or do i have to pull the oil pan and replace the whole line............ | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Check your e-mail. I sent you a pic of the oil line routing.
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | The oil line is all one piece. It goes through the block and attaches to the oil galley on the other side. No need to take off the oil pan, but drain the cooling system if it isn't already dry.
Harvester | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | thanks harvestor..........Tiny sent me a diagram in great detail on the system..........thanks for all the information........i hope to have all the parts by next week........put the head back on......repair oil line......install new pushrod..rocker arm...new gaskets..this project keeping me out of trouble...wink wink | | | | | Joined: Jan 2011 Posts: 19 New Guy | | New Guy Joined: Jan 2011 Posts: 19 | Just did a search and it looks like this post is related to my problem. Which hole in the head does this oil line go through? I tore this engine down 9 years ago, and did not take a picture.
Thanks for any help - picutes, diagram, hole count from front or rear.
Phil - 1950 216 | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | The pushrod side between cylinders 3 & 4 on my '38. I don't know if your '50 is the same. Someone will chime in if it's different.
| | | | | Joined: Jan 2011 Posts: 19 New Guy | | New Guy Joined: Jan 2011 Posts: 19 | Sorry folks for the dumb question. Pretty obvious once you sit the valve rocker assembly in place. Got the head on and ready to torque. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | The only dumb question is the one that doesn't get asked.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I'm not sure about the only dumb question is the one that isn't asked thing, you obviously don't work for my supervisor... | | | | | Joined: Oct 2014 Posts: 4 New Guy | | New Guy Joined: Oct 2014 Posts: 4 | can u please send me this stuff for the oil line replacement i have a bone stock 41 and this oil line is broken I have ordered one from Jim carter and a manual but want to start preparing thanks if u can send me any info !! | | |
