| | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 6 Member | | Member Joined: Oct 2002 Posts: 6 | Any secrets to getting the black ooze off the undersides of my '54 GMC? Grinding with a 3M disk seemed to smear it around and cover any exposed body parts with airborne sludge. I tried a citrus paint remover but 1) I hate to use chemicals 2) its hard to drink a beer with a respirator on. My hood is too big to fit into my blast cabinet. Suggestions would be greatly appreciated. | | | | | Joined: Jul 2000 Posts: 580 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 580 | Eastwood company has a product called "Undergone" #31130Z that has worked for me. | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | There is no easy, quick way. I heated about an 8 inch square area at a time with a handheld propane torch. Just enough heat to soften the undercoating, then scraped off the undercoating with a putty knife. Takes some time but did a good job of removing the old undercoating. Of course, I had the cab off the frame resting a the firewall on a cab dolly, made musch easier to get to. | | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | I had to do the same thing. The stuff from Eastwood wouldn't touch it. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I had to remove a bunch of undercoating when I worked on my truck. I did not find an easy way to remove the stuff. I used different techniques on different days. Sometimes I felt like sanding, sometimes I felt like gooping it up with paint stripper. Other days I felt like grinding with a wire wheel or a fiber 3-M stripper disk. Some days I used a stiff putty with a sharpened edge.
After many days of trying everything, one day I went out to my garage and the undercoater was all gone. Good Luck, it is tough stuff..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
