1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | My '59 came with no MC, just lines hanging loose at one end and a pedal hanging loose at the other. I've purchased the conversion bracket (made by CPP) and the appropriate master cylinder. The bracket instructions have one (poor) pic and assume you are removing an old MC. But I'm working from scratch.
I've read Cletis' tech tip but am still a bit confused. For example, he talks about a nut plate but my frame bracket seems different. And he also assumes you started with the old system in place.
YouTube has videos for '49-55 (1st) but I can't find anything on the web for '55 (2nd) to '59.
Does anyone know of a write up (with lots of pictures) that will help me get the bracket and MC installed, and pedal linkage in place?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I wonder if your original mounting bracket has been replaced with a farmer rig. Can you post a pic? | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | From the picture it would seem that you have the same mount for the MC that the AD truck has with one difference. Your frame plate is threaded. Mine had a plate that was threaded and slid behind the bracket in your pic. Original MC has 2 cast mount holes at the bottom of the cylinder. One to the front and one to the back. They would match the holes in the frame bracket and the two bolts go through to the frame bracket. So it would appear that the mounting is the same as an AD truck. The lines? A different story. There are some pics in this Tech Tip:http://www.stovebolt.com/techtips/master_cylinder/index.html I hope this helps some.
Steve H
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, that is mounted correctly.
It matters not where the ports come out. What matters is the bore size needs to be right for the wheel cylinders. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Are you running disc brakes? If so, I would strongly recommend running an 8 inch dual diaphragm booster. If not running discs, i would highly recommend running them.
As for CPP, i don't have anything nice to say about them. When you have a problem, they suddenly get very stingy. It is frustrating because they "guarantee" every part they sell for life. If you have a problem, however they try to make you buy another part. | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | I'm staying with drums all around, primarily for budget reasons. And this truck will see only light duty. I ordered this conversion kit through one of the standard vendors, but don't remember which one. I don't know about their customer service, but their instructions are almost worthless. One bad picture and steps that assume you're doing a bolt-off, bolt-on. They don't identify their parts except to say how many of each are included. So, for example, where does the one nylon insert nut go?
I wish I didn't have to be so needy here, but this kit is NOT what I expected!
And I'm wondering if I have all the brake linkage I should. I only have a pedal with it's curved shaft that was laying on the floor of the cab when I bought the truck.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | The brake pedal going through the floor is a 1/2 inch curved metal looking thing. That curved metal rod attaches to a much more substantial caet iron lever. The lever has about a 1 inch hole for a pivot which matches up to your bracket. The nylon nut should be used to attach the master cylinder plunger to the bracket/ pivot/ pedal. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The odd metal stamped piece is the answer to your first question. It fits into a slot on the pin and attaches with the short bolt to that hole just aft of the zerk.
The push rod angle discrepancy is discussed in my tech tip.
Yes on the return spring.
Don't know what the extra bolt are for. | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | OK, for the next poor newbie who's trying to figure this out like me, and who needs pics to understand, here's what I ended up with: http://i35.photobucket.com/albums/d...kup/installedfrominboard_zps5b3d0d94.jpgand a view from above: http://i35.photobucket.com/albums/d...%20Pickup/Installfromtop_zpsfd5b4858.jpgI added Grade 8 washers alongside the spacer to get the MC plunger in a straight line. Next step, make up some new steel lines, get the appropriate hoses, and dry fit everything. Then remove the MC, bench bleed, install, and bleed lines. If I'm real lucky I'll have working brakes when I'm done. Thanks for the help, everyone, and especially Cletis!! Again, this forum proves invaluable.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Don't forget the brake light switch on the cab with the spring arm that senses when the brake pedal has been depressed. You will probably not be able to adjust the pedal height correctly till thae cab is mounted. | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | That switch is another piece that was missing when I got the truck, so I have no idea where or how it mounts. But as you say, some things will better wait until the cab is set in place and a new wiring harness installed.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That looks great. Feels good, don't it? | | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | Yes sir, it does indeed feel good.
