5 members (JW51, 1955 1 Series, Gdads51, 55shaker, 1 invisible), 131 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
#1063501 10/20/2014 11:23 PM
Just thought I'd show you guys what a 19 year old did with his 3600.
I like the way he thinks.
http://67-72chevytrucks.com/vboard/showthread.php?t=647049
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #1063524 10/21/2014 12:54 AM
That's pretty slick. I've had a similar idea bouncing around in my head for while, except with 1/2 ton parts from a '99-'14 Silverado 1500.
Bill Burmeister
Whitedog #1063555 10/21/2014 2:34 AM
It's by far better than anything I've came up with. It's actually better than anything I've even seen anyone else come up with to be quite honest.
Those calipers he's using are huge and more than up to the task for any 3600, 3800, or 4100 truck.
"The Fake Truck"
Whitedog #1063834 10/22/2014 4:04 PM
I've got to try this.
Whitedog #1063855 10/22/2014 6:07 PM
That looks like a nice solution.
Any idea if the bore in the rotor fits the hub snugly?
If anyone following along I would recommend reasonable care in enlarging the stud holes as the stud location is what centers the wheel on the hub. And you want to keep a true bolt pattern so the wheel fits and all lug nuts torque up and carry the load equally.
The square part of the bracket might could be larger and thicker, wouldn't hurt if it still fits.
One idea I had is the whole thing could be burned out to shape and bends made in a press barke. Then only a small amount of welding to tie the two large "wings" together. May or may not make for a stronger product. A good steel supplier/fabricating shop should be able to do that without much cost.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #1063912 10/22/2014 11:34 PM
Nice work! Do you now need a proportioning valve between the new front discs and the rear Hucks? Would you consider making up a set of brackets for sale? I could do the rest but don't have access to a machine shop or welder. Thanks
Joe
1947 Second Series GMC 1-Ton Longbed
More pix in the Bolt Bucket
Whitedog #1063975 10/23/2014 3:50 AM
I've talked to Nick a few times, if I remember correctly, he enlarged the studs to the same as the '03 van that the rotors came off of. He also drilled the rotor so the set screw will hold the rotor in place.
He's actually spent alot of time on the project and laid everything out in a CAD program, including the hub.
"The Fake Truck"
Whitedog #1064033 10/23/2014 2:12 PM
I could cut out the brackets on my CNC plasma table, but would want to just pierce center holes rather than try and cut them out. May have to talk to him about getting a cad file of the parts.
Whitedog #1076461 01/01/2015 3:15 AM
Z
Z Offline
That's pretty slick!
Moderated by  Dusty53
