| | | Forums66 Topics128,203 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Not 1000 % positive,but that tank looks like one out of a 1 ton panel or a 47/48 pickup tank,before G M moved the tank into the cab behind the seat. regards, steve sr. | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | It's bigger than my 1/2 ton panel tank. Mine is about 26" long. I think the one tons had bigger tanks. | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Look very similar to the one I took out of my one ton AD panel/bus....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Article from below link, This gas tank is the same as the 1/2 ton “Single Unit” body trucks (Suburban, panel, and canopy express) during all the Advance Design years, 1947 through early 1955. With the 3/4 ton the truck has a longer frame so its gas tank could be longer and thus thinner yet it held the same fuel volume. it is important to realize this less depth allowed the tank to be higher above the ground. Therefore, it eliminated most tank contact with “high center” road rocks on dirt roads as with the 1/2 tons. To date, the 3/4 ton gas tanks are not being reproduced! Dimensions are: length 24", width 12 1/2", and depth 13". Source Underbed Gas Tank I do not think its a 47- early 55 1/2 ton Suburban, panel, and canopy express gas tank. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | This link is tanks for a 1/2 ton. One is my original, one is the new Repop from Jim Carter and the other is an extra I had to try fix... but the new ones came out first. Just FYI http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks002.jpg | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Looks like a one ton panel fuel tank to me as well.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 1954 3100 1/2 ton 16 gallon tank, panel, Suburban, canopy express, inside of frame on right side 1954 3800 1 ton 18 gallon tank, panel, canopy express, inside of frame on right side 1954 4502 1 1/2 ton 30 gallon tank, Medium School bus, outside of frame on right side Yep, probably a 47 to early 55, 3800 1 ton 18 gallon tank, panel or canopy express truck tank. Not sure on Year. Tank Volume & Fill Calculator plug in your tank dimensions minus seams Select Tank Type: Rectangle | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Oh man, i am embarrassed - somehow i did a typo in stating the length of the Tank!
It is 25 inches long, counting the Seam.
( Not 35 inches long ).
So, "Half Ton" tank I would expect...( rather than a 1 Ton Tank ).
So, should have read -
If counting the seam - 25 inches long. If counting the seam - 14 inches deep/wide. 12-5/8ths inches tall. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Those are the approximate measurements of my '54 Suburban tank. All Suburbans were 1/2-ton.
I need to also point out there were no 3/4 ton Suburbans, Canopy Express or panel trucks in the AD years. The Jim Carter quote Jorb listed is in relation to 3/4 ton trucks, not Suburbans, Canopy Express or panel trucks.
| | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Those are the approximate measurements of my '54 Suburban tank. All Suburbans were 1/2-ton.
I need to also point out there were no 3/4 ton Suburbans, Canopy Express or panel trucks in the AD years. The Jim Carter quote Jorb listed is in relation to 3/4 ton trucks, not Suburbans, Canopy Express or panel trucks. Thanks for that info! | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | So, remind me, please. There were only 1/2 ton and 1-ton AD Burbs, Panels, etc?
Thanks!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Between 47-55
1/2 ton and 1 ton panel and canopy express
1/2 ton suburban (with end-gate or with rear doors)
| | | | | Joined: Oct 2012 Posts: 28 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 28 | So here's my question . there's two outlets one on the side one bottom, which goes to the engine?
52 suburban 48 Palace
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | grgg, there's ONE outlet, and one inlet, check the sizes  Bill | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Mine has a drain cock on the bottom. The one on the side goes to the fuel pump. | | | | | Joined: Oct 2013 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 24 | Achipmunk nice work on your panal. Did you have any previous experience with welding? Or did someone else do it? I am in the same position. Debating if it something I should try to do myself. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yamboyak, I can stick weld but have no wire welder. I leave that up to my nephew.....but heck, I know I could do it  He just happen to have the nice new welder. Unless your wanting a show truck I say go for it. As long as we try hard, and do it two or three times, we can usually get a pretty doggone good job. I don't have much patience but the panel taught me some. LOL | | |
