7 members (GMCJammer51, TexasA&M48Truck, 55shaker, Gdads51, Pre '68 Dave, moparguy, 3B), 106 guests, and 3 robots.
Topics128,091
Posts1,056,390
Members48,442
Is there a reason they used castle nuts on the rear cab mount shackles? I bought some at the hardware store, right threads, but they are longer than the factory nuts. Okay to use as is, or could they be replaced with regular nuts. Thanks, Mike
I'm not sure why castle nuts were used as the bolts didn't have corresponding holes for split pins,at least the ones on mine weren't and as far as I know there were the originals.
Are the new nuts longer than the threads on the bolts?
Ideally there should be some exposed thread once the nuts are tightened down fully.
If not i'd be tempted to get either slightly longer bolts or shorter nuts,nylocs would be even better.
More pix on Flickr.
Mine are original too, perhaps there is a reason unknown to us. The threads are all under the threads, so should be good. thanks for the reply
While these may appear similar to castellated nuts they are actually Webster self-locking nuts which predate the nylon lock nuts now produced. They are still available in certain places (see link). They are also used on carb studs, shifter arms, exhaust studs, etc.
https://www.pegasusautoracing.com/productdetails.asp?RecID=3984
What Brad said. And if they don't go on tight once you reach the castle part of the threads, you can put the nut in a vise and tap on those castle peaks to restore their locking ability.
Carl
Thanks for the info Brad, I would have never thought! The new ones are nice and tight, not going anywhere, should be good in my book. Mike
