3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
37 Chev 216 3 speed
When I start up my truck and let it run at idle speed a strange noise comes from the transmission area. The noise disappears at higher revs, and also while the driving. At first I thought it might be the emergency brake linkage rattling in time with the engine, and in fact when the brake is on the noise reduces a little.
Have also disconnected the speedo cable but no difference - is there anything else I should be checking?
If you lightly press your foot on the clutch pedal does it go away?
My Blog
No lightly depressing the clutch makes no difference
Please have a listen on the video see following link
http://vid1260.photobucket.com/albums/ii568/37Chev/Truck/20141016_174845_zpsxmme5oig.mp4
