Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#1060271 10/05/2014 1:15 AM
not sure if this is the correct spot for this but here goes
took the truck out for the first drive 1953 3600 frame off resto, pumpkin is out of a 67 or 68 chev pu, 54 car 235. brake drums are all new bearing are new.
it was a short distance but I drove it three times.
engine performed well however;
1. I had an 8 inch puddle of oil under the flywheel after I shut her down.
thought maybe the cork gasket needed to soak and swell?
2. the harmonic balancer looks like it's wobbling but I used hotrods tap system and it's bolted on tight.
3.a833 tranny is noisy in all gears yes there is oil in it.
4. there is a sound like one of the brake drums is rubbing on metal. very un-nerving. I jacked up the truck and spun all the wheels and could not duplicate the sound.
other than those I think everything is running well. it need an alignment I think as it tends to wander. a little hard to tell since I was on a frontage road.
any thoughts would be appreciated.
thanks
rolf
1963 c10
rgie #1060278 10/05/2014 1:53 AM
1. It could be a pan gasket leak and/or a rear main seal leak and/or oil coming down from a valve cover leak? Try to see how high up the leak starts.
2. A harmonic balancer can still wobble after applying HRL's tap/bolt. The balancer hole could be distorted (mine was). Take off the fan belt and see if you can wobble the balancer.
rgie #1062409 10/15/2014 1:43 PM
UPDATE
I snugged up the oil pan bolts and now have no puddle.
the harmonic balancer is tight.
the right front brake drum (repop) was rubbing on the back plate. I had it machined down to match the old drum. no noise now.
tranny is still noisy.
going to take her in for a front end alignment.
thanks
rolf
1963 c10
rgie #1062510 10/15/2014 11:28 PM
You mentioned that it wandered. My '53 3600 did that when I got it and I found that one of the front leaf springs had broken at a shackle. I replaced all front springs and shocks and now it is perfect. I also found that my steering box was dry and needed adjustment and I filled it with lube (Corn head lube - John Deere)and that made a huge difference as well.
Just thoughts.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
rgie #1062640 10/16/2014 2:33 PM
john,
thanks
I had the springs done at Waco spring and clutch.
I rebuilt the steering box myself. (that maybe the problem!!)
new shocks all around.
I got new bearings and a different tie rod from one of the bolters that lived in ft worth.
i'm thinking with all the disassembly and re-assembly it needs an alignment.
1963 c10
rgie #1062649 10/16/2014 3:07 PM
I changed my king pins as well when I had it aligned.
