6 members (Donf, FAST55, Danielbolt, cmayna, rfs56trk, Oswald), 67 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
Does anyone know where I can get the interior windshield trim for a 52? This is the trim that has the defroster vents in it. I believe they should be SS. Also, they are U shaped, top bottom and outside wall. Top and bottom meet in the middle.
No problem finding exterior bit can find interior.
1952 Chevy Pickup - 3100 in process resto
Here is a shot of a full set of the interior parts (mid-49-53).
https://www.flickr.com/photos/advance-design_parts_co/11593840945/in/set-72157631868452754
The center section and cover clips are reproduced ClassicParts.com carries it under part# 32-130, there may be others.
The u-shaped pieces I am not aware of reproductions, post an ad in the Swap Meet here. A caution on them, they have clips and pads to aid in spacing and to keep the vent area open if you get used they are often rotted or missing from condensation build-up so check.
The only SS inside the cab on window trim I have ever seen is on the side windows like this.
https://www.flickr.com/photos/advance-design_parts_co/8129182561/in/set-72157631867396207
All windshield interior trim I have seen is painted. Most likely to avoid glare issues that SS would enable.
Early trim sets (47-mid 49) often have the more decorative cover clips, the corresponding u-trim has a tab extension for these to screw into. They will also fit if you can find them.
https://www.flickr.com/photos/advance-design_parts_co/8129177743/in/set-72157631867396207
https://www.flickr.com/photos/advance-design_parts_co/8331300940/in/set-72157631867396207
chucklaw25: I have a couple of extra sets. Need a good cleaning (I usually glass bead everything before priming and painting). Pay for the ride and they're yours. Send me your address and I'll let you know what the cost is.
That's great! Thank you. These are VERY hard to find!
Can you email me and I'll send you my address.
[email protected]
Mark
Is the trim piece still available? Where you able to determine the shipping cost?
Moderated by  ndkid275, Phak1
