| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | behind my cowl vent is rusted thru. the area between the windshield and vent. does any one know how to repair this?
Get busy liv'n or get busy die'n
| | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | Sorry. on my 1952 3100 Chevy.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | You will need to obtain some 16 ga material and make a patch panel. If it is just a few holes you can get away with placing some metal underneath and welding the hole up from the top and grinding smooth. A mig welder will be best for this. If you do not want to weld you can fiberglass underneath it and then put filler on top. You will need to clean the area under the cowl completely though to make the fiberglass hold. This is not an easy area to repair. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | MT has the patch [ removed from a orig.truck ] to fix your problem. Email me for more info. | | |
