3 members (Gib70, Nick in Manitou, Wally / Montana), 104 guests, and 4 robots.
Topics128,088
Posts1,055,998
Members48,430
#106234 07/01/2004 2:08 PM
behind my cowl vent is rusted thru. the area between the windshield and vent.
does any one know how to repair this?
Get busy liv'n or get busy die'n
#106235 07/01/2004 2:09 PM
Sorry. on my 1952 3100 Chevy.
#106236 07/01/2004 3:04 PM
Anonymous
Unregistered
Anonymous
Unregistered
You will need to obtain some 16 ga material and make a patch panel. If it is just a few holes you can get away with placing some metal underneath and welding the hole up from the top and grinding smooth. A mig welder will be best for this. If you do not want to weld you can fiberglass underneath it and then put filler on top. You will need to clean the area under the cowl completely though to make the fiberglass hold. This is not an easy area to repair.
#106237 07/03/2004 4:49 AM
Anonymous
Unregistered
Anonymous
Unregistered
MT has the patch [ removed from a orig.truck ] to fix your problem.
Email me for more info.
