| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | On a 1957 Chevy shortbed where does the fender brace that hooks in the frame attach to? There is one on each side of the truck and I cann't remember to save my own life. Thanks for your help | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Do you mean a round rod with a flattened ends w/ bolt holes? This is a rear fender brace, right?
I'll tell you what I did when I forgot which hole my rear braces bolted to. I hung the fenders, then crawled under it and loosely bolted the rod to the lip of the fender. This gave me the endpoint for one side, I just pushed the flat end of the rod against the frame and looked for a hole that matched. | | |
