4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#106221 11/07/2003 12:43 AM
Junior Member
Junior Member
I have a 4 1/2" electric grinder, does anyone know the best sandpaper/pads to put on to remove the rust and paint on my 53 chevy 5 window?
#106222 11/07/2003 1:48 AM
Typically 80 grit would be the ticket for paint and rust work. A slower turning, bigger surface grinder/pad combination would work better. The small angle grinders can get too agressive and create a lot of heat and remove too much material unless you watch really close.
Kevin Tetz at www.paintucation.com has an excellent video on metal prep and rust repair that you might want to consider purchasing. All of his videos are excellent info.
Bruce Palmer
[email protected]
#106223 11/07/2003 3:14 AM
That grinder spins at what, 10,000 rpm?
The only thing I have found that will hold up at that speed and cut both paint and rust is a braided wire cup brush. Straight-bristle wire brushes will fly apart and leave you picking wires out of your legs and arms. Most sanding disks are not balanced for high speed, and will buck and gouge or become shrapnel. If you use a braided wire cup, you must keep moving or it will scorch and warp the steel quickly.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#106224 11/07/2003 7:30 AM
3M makes some surface conditioning pads for the angle grinder. I haven't used them, but have seen them in Eastwood's catalog.
Fred
52 3600
69 C-10
#106225 11/08/2003 4:28 PM
3M makes paint/rust removal "pads" that have a shank to use in a drill motor. There is light thru corse pads. They are like scotch-brite material, but much tougher. I found them at "Osh".
Stuff flys off with very little effort.
#106226 11/09/2003 1:44 AM
Quote
We were talking angle grinder, not drill motor. Click Here
Fred
52 3600
69 C-10
#106227 11/22/2003 2:16 AM
Junior Member
Junior Member
The Cornwell tools truck sells them here in a 50 pack with the arbor. they run around $1 per pad. Great for cleaning up old stuck on gaskets. Also there are different versions for steel or aluminum. and different sizes.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
#106228 11/22/2003 5:00 PM
Scuuuzzz me Fred.....worthless information. :rolleyes:
#106229 11/27/2003 12:46 AM
go to your local hardeware store and get a couple
flap discs they come in different grits and fit the angle grinder they work great..
