| | | Forums66 Topics128,034 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | So I think my 1950 3800 had been rode hard and put away wet. Below is a pic of the firewall and how the cables were routed - looking to identify which hole is proper for each cable. Care to take a look and correct me if I'm wrong? In the pic, from left to right, I'm thinking: 1) Throttle and choke cables 2) Speedo cable 3) Temp Sensor 4) Oil pressure line 5) ??? (Fuel gauge sender?) http://i1131.photobucket.com/albums/m545/carmental2/Firewall_Cable_Routing.jpgAdvice? Thanks - Bruce | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I believe the hole you have marked Speedo cable is correct. The hole you have marked throttle and choke cables, also handles the temp sensor and oil pressure line. The grommet handles all four. The hole marked ??? is for the vacuum rubber line to your wiper motor. The two holes marked temp sensor and oil pressure don't exist on my '51, so I think they may not be original. Let's see what others think. Kent | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The last two holes mentioned above may be where the original inside dashboard brace attached to the firewall. All the others, Lightholder identified correctly based on my 1950 3100.
Drew
Drew
