| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Now that i have my carb issue sorted on my 55 235 and driving around i have been playing with firewall insulation slightly and such. With the new items installed new noises are being picked by me as the ambient noises go down.
Around the 2000 rpm area and up to the 2600 ish area when holding the pedal steady i get a chattering sound noise. Not a deep hard knock by any means. seems to be present only when under load when driving and not revving stationary. This sound like rod issues? Engine only has 1100 miles on it now.
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Detonation- - - - -back off on the ignition timing a few degrees. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | The cool thing about your situation is that you are very close to having the timing dialed in perfectly if you follow Jerry"s advice. Ball-on-the-needle timing is a good start. Seat of the pants is a better finish. Carl
