7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
Now that i have my carb issue sorted on my 55 235 and driving around i have been playing with firewall insulation slightly and such. With the new items installed new noises are being picked by me as the ambient noises go down.
Around the 2000 rpm area and up to the 2600 ish area when holding the pedal steady i get a chattering sound noise. Not a deep hard knock by any means. seems to be present only when under load when driving and not revving stationary. This sound like rod issues? Engine only has 1100 miles on it now.
Detonation- - - - -back off on the ignition timing a few degrees.
The cool thing about your situation is that you are very close to having the timing dialed in perfectly if you follow Jerry"s advice. Ball-on-the-needle timing is a good start. Seat of the pants is a better finish.
Carl
