| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 21 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 21 | Anyone know the factory color for the metal bed strips that hold the boards down? I am assuming the angle strips welded to the sides were body color, the other strips were probably black like the boards. I must be just about done if I am worrying about this!
One who knows that enough is enough will always have enough. Lao Tzu
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | You are correct. Angle strips body color, bed strips black but am not sure whether flat, gloss or satin. Bruce
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jan 2000 Posts: 21 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 21 | Thanks for the help. It was hard to paint those new boards black, but I am a slave to original.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark, Slave to original. Did you use gloss or semi-gloss coal tar to "paint" the boards  . Tim | | | | | Joined: Jan 2000 Posts: 21 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 21 | After discussion with the local paint guys I used a flat black porch paint that was recommended as being pretty tough. After sanding the boards I put it on without primer per their instructions. It looks real nice. I have the same paint on my porch (not black) and it has held up pretty well.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I should have read this before posting my question, can you let me know where I can call about the black porch paint?
Jake | | |
