1 members (Otto Skorzeny),
60
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | My fuel pump is leaking out the diaphram so will replace. What I don't know (and haven't looked close), is there a backing plate on the block after I remove the fuel pump? My concern is the push rod falling down and having to deal with that. Can I pull the pushrod out and grease it to stay in the up position? Is there enough room to pull the pushrod out to do this? Any suggestions will be appreciated. Thanks, Ray | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | be at ease, piece a cake, just pull off the pump and put the replacement on, if the rod slips down, push'er back, not a problem
Bill | | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
