4 members (Napco Man, NJC, carbking, Cosmo), 89 guests, and 3 robots.
Topics128,090
Posts1,056,443
Members48,443
1 Offline
My fuel pump is leaking out the diaphram so will replace. What I don't know (and haven't looked close), is there a backing plate on the block after I remove the fuel pump? My concern is the push rod falling down and having to deal with that. Can I pull the pushrod out and grease it to stay in the up position? Is there enough room to pull the pushrod out to do this? Any suggestions will be appreciated. Thanks, Ray
be at ease, piece a cake, just pull off the pump and put the replacement on, if the rod slips down, push'er back, not a problem
1 Offline
Thanks!
What rod? None on a 228.
