9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,113
Posts1,056,279
Members48,439
#1060117 10/04/2014 6:08 AM
I have a 41 1/2 ton was wondering if intake manifold was semi gloss black or a cast gray originally I have seen both ways
Thanks for any info
The intake was painted engine color(dark gray)
Right On Don!
What you're observing Crash, is what someone did to cover up
the rust which forms a week after the original factory paint
has burned off the exhaust manifold. A PO sprayed some
Hi-temp hot rod paint on it.
If you want to keep the look of bare, un-rusted cast iron,
'Calyx' works well but has to be reapplied every few months.
http://www.eastwood.com/calyx-manifold-coating.html
Here is an exhaust manifold with about two years use on it
that was treated with Calyx but not maintained real well.
http://www.pbase.com/dennygraham/image/124991344
This was the way it looked right after being treated while
mounted up on the engine.
http://www.pbase.com/dennygraham/image/114331484
dg
Denny G
Sandwich, IL
I touch up the Calyx once a year (Spring time post-hibernation activity). Mine lasts all year, as long as I do not get the manifolds wet and then forget to run the engine to dry them off.
Thanks Guys!!
Just re-read this, my mistake, you were asking about the intake,
not the exhaust. Dyslexia is a terrible burden you know.
Sorry,
dg
Denny G
Sandwich, IL
No worries Denny I needed info for the exhaust too.
Nice restoration you did on your exhaust manifold very clean work replacing the studs. the studs on mine look pretty rusted in, the threads are good so I don't think I want to try and replace them(I would hate to break one off)
Probably end up breaking the flange if they are to far gone.
That's why I had to build a new flange for the manifold in the
pictures. Apparently someone had tried to remove them
somewhere in the past and broke the flange off.
The new studs I made from SS and used brass nuts on them.
dg
Denny G
Sandwich, IL
Moderated by  ndkid275, Phak1
