8 members (MNSmith, frogfarmer, 1955 1 Series, walter74, Hotrod Lincoln, klhansen, TUTS 59, 1 invisible),
32
Mod | | | Forums66 Topics128,005 Posts1,055,258 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | not sure if this is the correct spot for this but here goes
took the truck out for the first drive 1953 3600 frame off resto, pumpkin is out of a 67 or 68 chev pu, 54 car 235. brake drums are all new bearing are new. it was a short distance but I drove it three times. engine performed well however; 1. I had an 8 inch puddle of oil under the flywheel after I shut her down. thought maybe the cork gasket needed to soak and swell? 2. the harmonic balancer looks like it's wobbling but I used hotrods tap system and it's bolted on tight. 3.a833 tranny is noisy in all gears yes there is oil in it. 4. there is a sound like one of the brake drums is rubbing on metal. very un-nerving. I jacked up the truck and spun all the wheels and could not duplicate the sound. other than those I think everything is running well. it need an alignment I think as it tends to wander. a little hard to tell since I was on a frontage road. any thoughts would be appreciated.
thanks rolf
1963 c10 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1. It could be a pan gasket leak and/or a rear main seal leak and/or oil coming down from a valve cover leak? Try to see how high up the leak starts.
2. A harmonic balancer can still wobble after applying HRL's tap/bolt. The balancer hole could be distorted (mine was). Take off the fan belt and see if you can wobble the balancer.
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | UPDATE
I snugged up the oil pan bolts and now have no puddle.
the harmonic balancer is tight.
the right front brake drum (repop) was rubbing on the back plate. I had it machined down to match the old drum. no noise now.
tranny is still noisy.
going to take her in for a front end alignment.
thanks rolf
1963 c10 | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | You mentioned that it wandered. My '53 3600 did that when I got it and I found that one of the front leaf springs had broken at a shackle. I replaced all front springs and shocks and now it is perfect. I also found that my steering box was dry and needed adjustment and I filled it with lube (Corn head lube - John Deere)and that made a huge difference as well. Just thoughts. John | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | john, thanks I had the springs done at Waco spring and clutch. I rebuilt the steering box myself. (that maybe the problem!!) new shocks all around. I got new bearings and a different tie rod from one of the bolters that lived in ft worth. i'm thinking with all the disassembly and re-assembly it needs an alignment.
1963 c10 | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I changed my king pins as well when I had it aligned. John | | |
