1 members (GMCJammer51),
69
Mod | | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 25 | Has anyone used a lower door skin to repair the problem area on the lower quarter between the door and the rear fender on a panel/burb?
Got pics of what's involved? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | using the skin won't really be any different than just using flat metal for that area, not a complex shape - what's involved is cutting, welding, grinding sheet metal, & finishing, same as any other corrosion repair - if you can handle those processes you can find some details on body work in the paint and body forum
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It is important to state what year on these questions. You can buy a piece that is for the "rocker" and possibly use it for the rib shape at bottom and around wells. Approx 40'' long. How can we give pics/advice of what's involved without seeing what's involved? Any metal should work, a door skin would work, 58-59 fleetside bed side pieces will work...... The semi-challenging part is the rib (as mentioned above re: rocker) but it is easy for someone with forming tools. Google: Flex Edge Wheel Arch . May help, may not. Bottom part of door skin available, 7" tall, $40. or skin from a donor door.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have been told that people use the lower door skin for that purpose, on AD panels. You could check Metal Man to see if he makes them. | | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | I'm using a lower door skin to replace some quarter rot in my 53 Suburban. So far I have only managed to cut the rust out. I have not gotten to the point of trimming the door skin to fit.
Marc | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I got the repair panels I needed from Jim Carter…. American made as I recall and they have the proper fender bead rolled into them to blend in the rear fender area. I needed that because the forward portion of the fender cutout was rusted completely away. Also, I welded up the gas tank hole, since I intalled a 20 gallon tank where the spare goes.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Carter has great stuff for AD Panel Trucks, wish he had the same for TF.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Carters panel patches are all hand made by MetalMan [Wheelwright Restorations], who would no doubt make any other patches he could get good patterns for - contact info here or usually can find him on e-bay Bill | | | | | Joined: Aug 2013 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 25 | MetalMan is where I planned on going for my rear corners which need replacing also but thought I could save some money by grabbing some door skin cut offs. Sometimes being cheap doesn't pay off.
Youngrodder...
Can you show me pic of what the area behind the lower rear quarter between the door and the rear fender is supposed to look like?
Anyone have a pic of this area cut away?
There also seems to be a rubber strip attached via a metal strip with screws to the body between the body and the running board. Of course that is destroyed by rust. | | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Yes, I can get you a couple pics. I hear you about spending money, but what I learned on my first truck was I spent ALOT of money on stuff that I could have easily made. This quarter repair is a good example. For me the rear fender arch was fine I just needed a small section appox 16" L x 7" H. In my case the lower door patch was cheap and should work fine.
Marc | | | | | Joined: Jun 2006 Posts: 49 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 49 | Keith-
Here are a few pics of what the lower quarter looks like. [URL=http://s79.photobucket.com/user/Youngrodder/media/DSC09885_zps31576b52.jpg.html][/url]
[URL=http://s79.photobucket.com/user/Youngrodder/media/DSC09884_zpsd2740357.jpg.html][/url]
If you need anymore pics just let me know.
Marc | | | | | Joined: Aug 2013 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 25 | oh yeah. i'm missing all that in the back about 2-3 inches up.  Looks like i'll be bending some steel and doing some fab. Thanks for the photos.
| | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Im also needing the rear corners for my panel. I contacted Jim Carter and asked if the rear corners had the bead rolled into them to match the bead around the fender area and they told me that there was no bead rolled into them.  Would the lower area between the door and rear fender have the bead rolled into it to match also? I have sent metal man a message on his website but it keeps coming back to my email saying there is an error and its delayed. Does anyone know of another way to contact him? Thanks for any help | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Carters panel patches are all hand made by MetalMan [Wheelwright Restorations], who would no doubt make any other patches he could get good patterns for - contact info here or usually can find him on e-bay Bill he also makes that odd ball one off sheet metal stuff that fits ONLY the one ton AD panels. He made my repair panels that go behind the rear fenders, that are a bit longer then the 1/2ton parts. AND yes they do have that round lip by the fenders. I have sent metal man a message on his website but it keeps coming back to my email saying there is an error and its delayed. Does anyone know of another way to contact him? Ray Stanley Wheelwright Restorations 92 Pine Street Wheelwright, MA 01904 1-413-477-6467 Hope this helps you........joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | | Oldog in Md. Unregistered | | Oldog in Md. Unregistered | Ray is my first stop when it comes to this type of fabrication , top notch service and you it is going to fit ...first time Dan | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks Joe for the info and pics. I appreciate it. And also thanks Dan
I will be giving Metal Man a call | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 |
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | I got my rear corners today from Ray and the look great. VERY happy with them.
Thank You for the info on how to contact him,it is very appreciated | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Wanted to ask if anyone has any tips or advice on how to go about getting the corners in?
Mine are pretty much rusted away so theres not much there to go by. Remove the rear fender and go from there?
Any tips or advice is greatly appreciated | | |
