5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#1059789 10/02/2014 5:52 PM
Will a 54 3100 dash fit into a 53 3100 without a lot of modifications? I have a really good 54 dash and my 53 dash is all rotted. Any help would be appreciated. Thanks
rock331 #1059811 10/02/2014 9:36 PM
What would you consider being "a lot of modification"?
How much metalwork experience do you have?
The shape/size of the two dashes are different, not just with respect to the two windshield openings.
There are at least 25 spot-welds in each dash/cab that will have to be cut out.
The donor dash would have to be fitted and then welded into place.
Maybe someone who has accomplished/attempted this will respond. That would be the best information for you to consider.
rock331 #1059814 10/02/2014 10:05 PM
Personally I think this one is a bad idea. There are actually 39/41 spot welds to consider, a wiper motor bracket change and potentially the steering support/cowl actuator. Lots of work and the area with the majority of spots along the windshield pinch as Tim mentions is not even close to a match. I have cut several of these out for sale to make repairs but never wanted to attempt replacing one. If you decide to do it take some pictures as I am sure it would be of interest. Here is the breakdown on the spots: 25 spots along windshield, 2-4 on center divider (another issue) and 5 each side of the dash (not many of these can be removed with a spot cutter).
https://www.flickr.com/photos/advance-design_parts_co/12512838825/in/set-72157631868452754
rock331 #1059831 10/02/2014 11:47 PM
Thanks guys. My big question was about the windshield area. What would be the best idea for fixing mine. Replace whole thing or cut a replacement one where the bad areas are? Thanks again...
