1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,090 Posts1,056,376 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | I got the replacement glass for my truck. The windshield is in but , I cant get the glass out of the doors. The clutch head screws are in there good. The drivers side is stripped right out. Someone got a tip for removing stubborn bolts especially clutch heads? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, Josh, Rusted bolts/nuts/screws are par-for-the-course for these projects. Dealing with clutch-head hardware is really no different than dealing with any rusted, stubborn old hardware (in fact, the clutch-head itself allows a better "grab" by a screwdriver, compared to other commonly used old hardware heads). If you do not have clutch-head screw-drivers (or driver bits), use a regular flat-tip screwdriver that fits the clutch-head (or, grind a regular tip to tightly fit the clutch-head). There are two Stovebolt.com Tech Tips http://www.stovebolt.com/techtips/#bondo]on bolt/screw removal in the General Body Work section. Patience, penetrating oil, and good use of swear words seem to help. | | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | Thanks Tim. Of all the bolts holding both windows... 1 was able to be backed out using a custom made clutch head bit. Drivers side is now stripped. rounded completely and passenger side heads are still ok. Can The track that holds the window come off regulator and come out of door , w window on it? | | | | | Joined: Mar 2013 Posts: 235 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 235 | I don't know much about the window removal in a 49, but seems like most door windows only come out in order with the vent window retainer removal. Tech tips and searching lots of threads helped me figure mine out. I happened to see this bolt removal package at Lowe's last night. I don't know if things like this work or not or are gimmicks. I have drilled my share of bolts out when I have no other option. Irwin bolt removal kit | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | The 49' regulator comes out the bottom and the glass out the top. The way it slips into the glass and a small inner track I am not sure if you could get it out this way. You could try completely unbolting the regulator from the door and seeing if it would collapse enough. Having had this problem on trucks I was parting I know you have a couple of alternatives. You can use a thin cutting blade to grind the clutch heads off. You would then need to remove them from the frame. I have done this by welding them, see my tech tip: http://www.stovebolt.com/techtips/bolt_broken_remove.htmlYou can also get a small set of vice grips (with good teeth) and clamping the bolt heads, turn them a small amount eventually getting them loose enough to remove. Here is a slide set with some good pictures on positioning and removal of the glass, let us know if removing the regulator from the glass is possible, good luck. https://www.flickr.com/photos/advance-design_parts_co/sets/72157641244124604/ | | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | Hijack alert! Thank you Brad for the posting of the above slides. I have been battling with my wiper motor switch rod. I had it upside down, backwards and possibly sideways. You are a saint! Carl
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Hi Josh,
I used a small drill bit a drilled the slot in the clutch head screws. Drilled carefully through the clutch head screw. Got a set of easy outs from auto parts store in the tool section. Sprayed PB Blaster on the screws and screwed the easy out into the screw until tight. Backed out the easy out and out came the the &%@# clutch head screws. This was the easiest thing I could find to do since the side window channels are extremely narrow.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Looks like you got it Tim. Doesn't look like this will help you but....it might help someone else in the future. I fought with this stuff just like you did for years, then, I was helping a friend disassemble his AD and was doing battle with the clutch head screws behind the door panel. Nothing would budge them, tried lots of leverage also one of those hand and hammer impact drivers like you use on your Harley. He had a Makita 18v drill and impact driver set and said lets try the impact driver. With a smirk on my face I said sure, that little 1/4" drive drill is gonna get out what we can't get out with a breaker bar or hammer driver. Son of a beach, every single one of them popped right out with one burb of the Makita, no sweat. We had taken the doors off and left the hinges because every one of the hinge bolts in the cab were also frozen. Again, had soaked them down with PB Blaster several times, tried the hand and hammer bit, breaker bars, tried to tighten them then loosen, some were even starting to round off, nota one budged. We put the 1/4" hex to 3/8" square adapter in the Makita and to my amazement every one of them came right out. I've posted this before, but I stopped at Home Depot on the way home that afternoon and bought me a boxed set Makita drill & driver. Some weeks later we had the badly rusted bed off in the drive and once again, the 18v driver spun screws out that in the past I would have ended up drilling or chiseling out. Best investment I've made in the last twenty years.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | I removed mine by heating the screw head with a brazing tip on my torch set. Every screw backed out easily. No damage to old glass ( have new glass), just a little smoke from mounting tape. Also heated steel window trim to remove old glass without bending trim. Worked well. Old screws are still in fine shape if needed to be re-used. Just saying.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
