6 members (rfs56trk, TrknGMC, Gray_Ghost, Wally / Montana, walter74, 1 invisible), 75 guests, and 4 robots.
Topics128,056
Posts1,055,803
I have a 235 w/ a fenton manifold and would like to no if there is a mod for getting clearance by the manifold? Any help out there? thanks
what model year truck? i have no clearance problems in my 56
What year truck?
Fenton Intake Manifold?
Fenton Exhaust Manifolds?
The Fenton dual intake manifold gets rubbed by the 1954 3-speed shifter linkage (47-55, I would guess) .
50 chevy 3100, fenton dual manifold, shifter linkage correct.
Am considering the same setup and have been told of the interference. Was at a car show last week and found a 49 3100 with this setup. Owner just took a grinder to linkage and trimmed it back a little. Solved his problem - and hopefully mine in near future.
I accomplished this by cutting the arms and extending them in a dogleg fashion to avoid the intake. It took quite a bit of trial and error to get things correct but has worked well. See here.
This picture shows where I cut the arms.
You Tube
Curt B., That is slick.
Drew
Curt thank you for showing me how it done. You did a beautiful job, and confirmed my thoughts about how this could be done.
Thanks for the compliments guys. Oldschool; just tack the arm extensions and jump in the truck and check the throw of the shifter. You'll probably need to do do this a few times until you're happy. Also I scared up another shift box and rods to modify keeping my originals just in case. IIRC I cut about 2-3" off the rods.
You Tube
