| | | Forums66 Topics128,059 Posts1,055,818 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 5 New Guy | | New Guy Joined: Sep 2013 Posts: 5 | I have a 235 w/ a fenton manifold and would like to no if there is a mod for getting clearance by the manifold? Any help out there? thanks
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | what model year truck? i have no clearance problems in my 56 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year truck?
Fenton Intake Manifold?
Fenton Exhaust Manifolds?
The Fenton dual intake manifold gets rubbed by the 1954 3-speed shifter linkage (47-55, I would guess) .
| | | | | Joined: Sep 2013 Posts: 5 New Guy | | New Guy Joined: Sep 2013 Posts: 5 | 50 chevy 3100, fenton dual manifold, shifter linkage correct. | | | | | Joined: Sep 2014 Posts: 21 New Guy | | New Guy Joined: Sep 2014 Posts: 21 | Am considering the same setup and have been told of the interference. Was at a car show last week and found a 49 3100 with this setup. Owner just took a grinder to linkage and trimmed it back a little. Solved his problem - and hopefully mine in near future. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I accomplished this by cutting the arms and extending them in a dogleg fashion to avoid the intake. It took quite a bit of trial and error to get things correct but has worked well. See here.This picture shows where I cut the arms.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Sep 2013 Posts: 5 New Guy | | New Guy Joined: Sep 2013 Posts: 5 | Curt thank you for showing me how it done. You did a beautiful job, and confirmed my thoughts about how this could be done. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Thanks for the compliments guys. Oldschool; just tack the arm extensions and jump in the truck and check the throw of the shifter. You'll probably need to do do this a few times until you're happy. Also I scared up another shift box and rods to modify keeping my originals just in case. IIRC I cut about 2-3" off the rods.
