| | | Forums66 Topics128,186 Posts1,057,305 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | I have some numbers off of an engine, I am wanting to know if I have deciphered them correctly. block casting code 3764476 58-62 235 block date Con 4 B39 Feb. 3 1959 engine serial # F 204 J Flint Feb. 4 truck engine head 3836848 Is this a 1959 235 which should be a full pressure engine. Any other help with what I have would be appreciated. I'm wanting to put this in a 1953 truck. Thanks, Mel
If it ain't broke, fix it till it is
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You are correct.
F 2 04 J F = Flint, MI 2 = Feb 04 = 4th J = 3100
It is a 1959 235, and it would be a high-pressure engine.
Use your 1953 clutch housing and the starter that matches the voltage of your electrical system. Use the flywheel/clutch-assembly that matches the starter.
| | | | | Joined: Oct 2008 Posts: 19 New Guy | | New Guy Joined: Oct 2008 Posts: 19 | Thanks for the confirmation...I'm sure there will be many more questions. It is actually a complete engine & transmission, so I should be good to go. Checking into it, probably going to do a rebuild...any comments/suggestions? What would be an approximate cost to do a rebuild?
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I had a full pressure 235 completely redone, hot tanked, new cam/bearings lifters, valves, seats, timing gears, oil pump, pistons, rings, main and rod bearings, and all of the machine work for $2300 parts and labor. I assembled the engine myself. I had a few issues and the machine shop was very helpful in solving them. Pick your machine shop carefully. Just remember that a busy shop is busy for a reason. They very likely take care of their customers, and get a lot of good word of mouth, and return business. Carl
