6 members (52Carl, frogfarmer, Cletus1950, Rustnut, KEVINSKI, Hotrod Lincoln), 86 guests, and 2 robots.
Topics128,177
Posts1,057,060
Members48,460
After a bad summer health wise i decided after feeling better to put the new brake shoes on the rear. (51 chevy half ton) Took the truck for a ride all was well, It sat in the garage for about a week till i took it out for a ride again and for about a mile or so the rear tire(While Braking) locks up for a second making a small squeal when the rubber meets the road. This goes away after driving the truck maybe 3-5 miles,does not come back till the next drive after sitting over a few days. Took it apart looked ok ,adjusted the brakes back a bit SOS,should i get the drum cut to clean it up or ??????? Thanks for any feedback BJF
could be slight contamination like fingerprints on the shoes, will wear off, turning the drums will not help, but will shorten their useful life, might give them a rubdown with sandpaper and wipe them and the shoes with some Brake-Kleen .... next cruise try throwing some weight in the back of the bed
WILL DO. THANK YOU
Riding in the Passing Lane
If you did not o-haul or replace the wheel cyls. you need to. This must be done every time you replace the shoes. Your emergency brake cables may be adjusted up too tight or the cables are binding. It helps to file a champher on the edge of the shoes.
1972 Chevy c10 Cheyenne Super
A brake shoe backed off too far can also 'grab' on initial application.
I'm not sure if you've road tested the truck after backing the 'offending' shoe off,did it cure the problem?
I agree with Wrenchbender,although it's a while since I've done brake shoes I used to file a slight chamfer on the leading edge of each shoe too.
More pix on Flickr.
