| | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Here's one for guys who have experience with replacing a pinion or the Patricks 3.55 conversion: How much play is acceptable between the pinion splined shaft and the driveshaft? The manual shows using a big old puller for removing and replacing the pinion shaft. So must the splines themselves always be a tight fit? Or will the pin hold the whole setup together? Mine had a broken pin, and the splines are a loose fit.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | It would probably be better to acquire a tighter-fitting sleeve if possible. Every time you shift, or change throttle position the spline will work itself back and forth and wear the sleeve a little more. Eventually you'll get a click noise from the slack. Jerry
| | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks, yes, that's what I was worried about. The various instructions dont mention how snug the spline fit itself has to be vs. how much tightness/stress is taken by the pin. Has anyone pinned a loose fitting spline to get it tight enough?
