8 members (TexasA&M48Truck, Peggy M, 1955 1 Series, CuzzFuzz, greenie-reddy, Forty9, Hotrod Lincoln, thekid1950), 50 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
#1058383 09/25/2014 2:56 AM
anyone know where i can get nuts bolts and washers for toe panel. Its for ebrake it attaches to cab bottom thanks
jimbo 24 #1058393 09/25/2014 3:24 AM
Do you have an Ace Hardware close to you. They usually have a great selection of nuts and bolts ect.
jimbo 24 #1058461 09/25/2014 3:25 PM
yes o do but do u know what size i need and how long bolts r
jimbo 24 #1058467 09/25/2014 3:36 PM
I don't know the actual size....and not sure what model your working on. However, I'd buy a couple of each size and see which "fills the hole" best. I also use the shortest that will work. Just my opinion.
jimbo 24 #1058475 09/25/2014 3:55 PM
sorry its a 52 1ton chevy
jimbo 24 #1058575 09/26/2014 1:40 AM
Jimbo, I may be getting old but for some reason I don't remember seeing any bolts holding my toeboard in place and I replaced half of it......of coarse this might be because it was all rusted out smile
Moderators don't like double post but this is a good question for the paint and body forum.
jimbo 24 #1058626 09/26/2014 10:43 AM
Bond Villain
Bond Villain
If it will help him get his question answered better, I don't have any issue with a double post. Especially in a cross-over situation like this.
Wish I could help, but my AD 1-ton is the older style with the hand-actuated parking brake next to the gear shift.
Hopefully, someone with the newer 1-ton will post the answer in here, but if not -- Check the Gallery for any of the '52 and newer 1-tons and contact some of those guys -- maybe they can help you. Or a call to Jim Carter.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
jimbo 24 #1058738 09/26/2014 11:34 PM
According to my Factory Assembly Manual, which I recommend you get a copy if you can, I don't see any bolts associated with the hand or foot operated parking brake. However in one of my pics you can see in the upper right hand corner bolts that I think have something to do with holding the floor mat on the toe panel. There are matching bolts on the driver side as well. Are these the bolts you're talking about?
Dave Baird
1951 Chevy 3803
jimbo 24 #1058745 09/27/2014 12:09 AM
Mine is all apart but here is a picture prior to disassembly.
http://s1142.photobucket.com/user/52_Ton/media/100_2432.jpg.html?sort=3&o=16
Not sure if it will help you.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
jimbo 24 #1058781 09/27/2014 4:22 AM
dave i have one but it just shows me the part. and yes in your pic it bolts i guess to firewall but how
Moderated by  Dusty53
