| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | What should be the top speed for my '41 1 1/2 ton with the 235 four speed? I know I wont win any races but I hate having a long line behind me
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't expect to 'cruise' at over 50, you might push it to 60 on a downhill to get to a wide spot to pull over and let'em pass Bill | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thanks. That's kind of what I thought. As for tires and rear end, I will have to get back to you
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I think he has a single speed rear (not sure the ratio) and 7.00-20 or 7.50-20 tires.
Grigg | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | 45mph on a good day.. its what it is. LOL http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | That's about where my 42 1.5 is happiest, 45-48. Mine has the 261, 6:17 rear and 750x20s, Feels like 55-60 though, Ha Ha. | | | | | Joined: Sep 2012 Posts: 170 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 170 | Open the front window all the way and your cowl vent, you'll only be doing 45 or 50 mph, but it feels like alltruck72 said, 55 or 60.....lol. Watch out for hornets though. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | My 46 with a single speed 6:17 rear and 8.25 tires will cruise well at 50-53. I have had it to 65 but it was screaming. 55 isn't that bad, but 50 seems to be what it likes.
I rebuilt the 235 last winter and it still has the babbited rods with .030 over pistons. It's all stock. Even the radiator is original. I do run up around 190-200 degree's on a very warm day on the interstate, so if it is really hot out I tend to keep it under 45 for long periods of time. I have upgraded to a 12V alternator
I drive mine regularly on the interstate and in town. About 100 miles a week on average. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Anyone know what speed to expect out of my 57 GMC LCF 2 ton? I have been driving it around the place, but not out on the open road yet. It has the 270 I6 engine, 2 speed rear, with 6:40/8:72 gears, SM420, 4-speed tranny. 8.25x20 tires. I too, was wondering what the top cruise speed would be, without the engine screaming.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Old GMC, I would imagine about the same as me, maybe a few more miles with the rear in high gear. It doesn't matter what kind of hours power for your top speed. It matters what engine RPM you can run and what gearing you have. The 270 should have a little more torque and horse power, but I would imagine it has the same power band....
Just my $.02 worth. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Thanks Randy. I can live with 50. I don't think I want to drive it any faster than that. After all, it IS 57 years old, with no seat belts. lol
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You'll be fine at 50-55. The steering and brakes will help you decide the sweet spot for your truck going down the road. As long as your comfortable and it feels right who cares how fast your going. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I'd say 52-55 would be your "happy spot". That's where my T.F.'55 "likes" it. I still have about 1/4 inch of footfeed left,but I don't like to make "it" scream. | | | | | Joined: Apr 2005 Posts: 242 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 242 | What speed you can go is not that important it is the RPM that the engine can handle. Was told at one time not go over 2200 RPMs on a babbit pounder myself I would keep it a 2000 Rpms to be safe. Hope this helps.
Marv. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Don't be afraid of you babbit engines, they were designed to make max HP at well over 3000 rpm. Running all day long between 3000 and 3500 rpm shouldn't be a problem on a healthy engine. Mike B  | | |
