8 members (MNSmith, Samantha, cmayna, Phak1, 66flea, Jon G, CATMAN, 1 invisible),
44
Mod | | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 802 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 802 | I am understanding that the Fulton 807 visor was the standard visor for the A.D. trucks. http://53truck.ez15loan.com/howto/fulton-spec.htmAnd just to confuse matters, a Fulton model 603 in indicated to be used on a '48 Chevy truck in this document as you scroll down a way: http://www.indfloorcoating-repair.com/fultonsunshield.htmThe only reference I can locate in determining if a Fulton visor is an 807 model is that the dog bone brackets have mounting wings that are squared-off on the ends. Is there an other way to positively I.D. a Fulton 807 model? Is there a # stamped somewhere? The Fulton medallion on the end bracket does not appear to be of any help. I would like to be able to make a positive visual confirmation before making an offer on one. Thank you. LUKE
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've never found a number stamped on my Fulton anywhere. Sorry I can't help with that. The only differences I've seen personally are the position of the upper foot of the end bracket and whether it has a center support (split windshield) or not. As to which number is which I'm no help at all. Good luck with your search.
| | | | | Joined: Nov 2012 Posts: 257 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 257 | | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | There's a guy in AZ that's an expert on Fultons. Has a ton of new in box ones. I'll PM his email address to you.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's likely the guy with the handle Mother Trucker in the link above. Lot of info there.
| | | | | Joined: Sep 2014 Posts: 21 New Guy | | New Guy Joined: Sep 2014 Posts: 21 | Can you provide his email to me also? Looking for a visor for my 49 3100. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | my 1000 series is stamped on the under side under the center section. its stamped 1005-R | | | | | Joined: Dec 2009 Posts: 292 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 292 | or go on ebay search for fulton visor in ebay motors look for a seller named loopystuff he has about every visor made you could contact him through his seller info im sure he would know. hoppe this helps.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | They are stamped on the edges of each side,mine is a 800. looking at my picture you will see "insert yellow end here" right after that you will see # 800 stamped in it. you have to really look to see it. I hope this helps you. stamped model number Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
