4 members (TUTS 59, mick53, Bill Hanlon, dt235sd), 111 guests, and 1 robot.
Topics128,157
Posts1,056,892
Members48,458
I am understanding that the Fulton 807 visor was the standard visor for the A.D. trucks.
http://53truck.ez15loan.com/howto/fulton-spec.htm
And just to confuse matters, a Fulton model 603 in indicated to be used on a '48 Chevy truck in this document as you scroll down a way:
http://www.indfloorcoating-repair.com/fultonsunshield.htm
The only reference I can locate in determining if a Fulton visor is an 807 model is that the dog bone brackets have mounting wings that are squared-off on the ends. Is there an other way to positively I.D. a Fulton 807 model? Is there a # stamped somewhere? The Fulton medallion on the end bracket does not appear to be of any help. I would like to be able to make a positive visual confirmation before making an offer on one. Thank you.
LUKE
Ex Hall Monitor
Ex Hall Monitor
I've never found a number stamped on my Fulton anywhere. Sorry I can't help with that. The only differences I've seen personally are the position of the upper foot of the end bracket and whether it has a center support (split windshield) or not. As to which number is which I'm no help at all. Good luck with your search.
Haunting the SBP since 2001
There's a guy in AZ that's an expert on Fultons. Has a ton of new in box ones. I'll PM his email address to you.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Ex Hall Monitor
Ex Hall Monitor
That's likely the guy with the handle Mother Trucker in the link above. Lot of info there.
Can you provide his email to me also? Looking for a visor for my 49 3100.
my 1000 series is stamped on the under side under the center section. its stamped 1005-R
or go on ebay search for fulton visor in ebay motors look for a seller named loopystuff he has about every visor made you could contact him through his seller info im sure he would know. hoppe this helps.
They are stamped on the edges of each side,mine is a 800.
looking at my picture you will see "insert yellow end here" right after that you will see # 800 stamped in it. you have to really look to see it. I hope this helps you.
stamped model number
Tim
1951 3100 Chevrolet
