4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
Has anyone done a Tech post on how to remove the drive shaft on a 1941 1/2 pickup? I need to replace my clutch.
Wayne
Wayne Selway
Wayne,
Maybe this will help you.
Propeller Shaft Disassembly
Clutch
Harold
Harold
i undid my rear springs and removed the whole torque tube assembly and
got rid of it
I jacked up the rear of the truck so the differential and axle were hanging down on the springs as far as possible, this gave me enough leeway to remove the torque tube from the transmission without removing the springs or axle. Learned about doing it that way from either a posting or tech tip on this site.
Very nice truck. Some day I will get there. I removed the Transmission Cross Member and that let the drive shaft drop down and gave me more than enough room to pull the transmission.
Thanks for the help.
Wayne
Wayne Selway
