| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | Hi All After 5 years and too much money I am driving it and its almost done. Drivers door latch and window to fix. Deck to make. Check it out You CAN finish a truck. My 1947 Canadian 1.5 ton http://imgur.com/a/a3FEV#0Use the previous and next buttons to run through the shots. Click on the main pic for fullsize. Engine is a 1985 Holden 3.3/202 CI with factory EFI manifold, 1998 Holden Chev V6 EFI gear, megasquirt controller. 1985 Holden 5 speed. Everything else as factory. cheers
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Very nicely done!
Great color. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Not many 1.5 tons get a new lease on life like this one did. And it looks a lot better than it did on the showroom floor. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy anyoldiron, very nice, thanks for sharing, keep up the good work. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | |
