4 members (mick53, 1955 1 Series, klhansen, Shade Baby), 101 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
#105712 12/21/2002 1:52 PM
Z
Z Offline
Getting closer! There may be light at the end of the tunnel for my 51-3100 yet. I have purchased the crossmembers and front and rear tail gate new. I want to DP90 the parts. What is the best way to prepare the bare metal? Would wiping down with lacquer thiner do the job? Some sort of metal prep? Don't want to go to the trouble of sand blasting if I can help it. Any info ? Many thanks in advance Zeker6
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#105713 12/21/2002 5:50 PM
Don't wipe it with anything, after sand blasting shoot a coat or two of PPGs DX1791 etch primer, then without sanding the DP90. Then on any part that you are "just painting" like a frame componant you can paint also without sanding! That is the way to paint "hard parts".
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#105714 12/21/2002 7:35 PM
He is talking about new body pieces, not sand blasted pieces. Shouldn't he at least degrease them?
54 3100 with 235
62 flatbed dump C60 with 261
#105715 12/21/2002 10:14 PM
I'm sorry, yes you would want to wipe them down with a PROPER wax and grease remover. You could wipe with lacquer thinner to get a lot of grease off or something but then be sure to use a real wax and grease remover. Then sand or scuff good with a red 3M scuff pad.
1948 Chevy Pickup
