| | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | Getting closer! There may be light at the end of the tunnel for my 51-3100 yet. I have purchased the crossmembers and front and rear tail gate new. I want to DP90 the parts. What is the best way to prepare the bare metal? Would wiping down with lacquer thiner do the job? Some sort of metal prep? Don't want to go to the trouble of sand blasting if I can help it. Any info ? Many thanks in advance Zeker6
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Don't wipe it with anything, after sand blasting shoot a coat or two of PPGs DX1791 etch primer, then without sanding the DP90. Then on any part that you are "just painting" like a frame componant you can paint also without sanding! That is the way to paint "hard parts".
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | He is talking about new body pieces, not sand blasted pieces. Shouldn't he at least degrease them?
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | I'm sorry, yes you would want to wipe them down with a PROPER wax and grease remover. You could wipe with lacquer thinner to get a lot of grease off or something but then be sure to use a real wax and grease remover. Then sand or scuff good with a red 3M scuff pad.
